Huawei P9 Earpiece Speaker Replacement
Выберете то, что вам нужно
  1. Huawei P9 Earpiece Speaker Replacement, Back Cover: шаг 1, изображение 1 из 3 Huawei P9 Earpiece Speaker Replacement, Back Cover: шаг 1, изображение 2 из 3 Huawei P9 Earpiece Speaker Replacement, Back Cover: шаг 1, изображение 3 из 3
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Huawei P9 Earpiece Speaker Replacement: шаг 2, изображение 1 из 2 Huawei P9 Earpiece Speaker Replacement: шаг 2, изображение 2 из 2
    • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
    • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
    • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Huawei P9 Earpiece Speaker Replacement, Fingerprint sensor: шаг 3, изображение 1 из 2 Huawei P9 Earpiece Speaker Replacement, Fingerprint sensor: шаг 3, изображение 2 из 2
    • Disconnect the fingerprint sensor using a spudger.
  4. Huawei P9 Earpiece Speaker Replacement, Earpiece Speaker: шаг 4, изображение 1 из 3 Huawei P9 Earpiece Speaker Replacement, Earpiece Speaker: шаг 4, изображение 2 из 3 Huawei P9 Earpiece Speaker Replacement, Earpiece Speaker: шаг 4, изображение 3 из 3
    • Loosen the seven Phillips #00 screws on the motherboard.
    • On one of them might be a sticker. Remove it.
    • Unplug the antenna cable.
    • The metal plate covering the battery connector has two little hooks on each side. Use a tweezer to free them and unhinge the plate towards the top.
  5. Huawei P9 Earpiece Speaker Replacement: шаг 5, изображение 1 из 2 Huawei P9 Earpiece Speaker Replacement: шаг 5, изображение 2 из 2
    • Disconnect the volume button cable and the display cable …
  6. Huawei P9 Earpiece Speaker Replacement: шаг 6, изображение 1 из 2 Huawei P9 Earpiece Speaker Replacement: шаг 6, изображение 2 из 2
    • … as well as the battery connector and the cable running to the daughter board.
  7. Huawei P9 Earpiece Speaker Replacement: шаг 7, изображение 1 из 2 Huawei P9 Earpiece Speaker Replacement: шаг 7, изображение 2 из 2
    • Now you can lift out the motherboard to access the earpiece speaker.
    • Be careful with both cameras since they are still connected to the motherboard.
    • The earpiece speaker ist fixed with an adhesive foam gasket.
Заключение
Dominik Schnabelrauch
Участник с: 11/23/16
228 969 Репутация
Автор 682 руководств
Команду
iFixit Участник iFixit
Staff
118 членов
Автор 19 410 руководств
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 3
За последние 30 дней: 7
За всё время: 2,509
