Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
First switch off your phone and remove the SIM card tray.
Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
Loosen the seven Phillips #00 screws on the motherboard.
Unplug the antenna cable.
The metal plate covering the battery connector has two little hooks on each side. Use a tweezer to free them and unhinge the plate towards the top.
Disconnect the volume button cable and the display cable …
… as well as the battery connector and the cable running to the daughter board.
Now you can lift out the motherboard to access the earpiece speaker.
The earpiece speaker ist fixed with an adhesive foam gasket.
