Введение
Use this guide to replace the front camera in your Huawei P9 Lite.
Выберете то, что вам нужно
Use an opening pick to unclip the rear cover, starting from the bottom corner.
Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
Twist the opening pick to lever the back cover away and loosen it from the adhesive.
When the back cover is freed from the adhesive you can pop it off by hand completely.
Remove the nine Phillips #00 screws that secure the metal shield plate.
Use a spudger to disconnect the fingerprint sensor from the motherboard.
Peel the NFC antenna cable off of the metal plate.
Use a spudger to lift the motherboard carefully.
Remove the motherboard assembly.
Disconnect the front camera flex from the motherboard.
Flip the motherboard over and thread the flex cable through the opening and take the camera away.
5 участников успешно повторили данное руководство.
