Введение
Use this guide to replace the camera in your Huawei P9 smartphone. When reassembling your phone apply new adhesive where it is necessary.
Выберете то, что вам нужно
First switch off your phone and remove the SIM card tray.
Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
5 участников успешно повторили данное руководство.
