Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Use this guide if your Huawei Union will not charge when plugged into a charger or begins losing charge faster than previously observed.
Выберете то, что вам нужно
Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off.
Use the flat end of a spudger, or fingernail, to lift up the battery and pull out.
Remove the thirteen 3mm Phillips #00 screws from the back panel.
Firmly hold the second ribbon cable's plastic film cover and pull up to disconnect.
Wedge the flat end of a spudger underneath the motherboard and pry upwards to separate it from the frame.
Еще один человек закончил это руководство.
