Введение
Use this guide to open your Huawei Watch 2 for repairs.
Выберете то, что вам нужно
Before starting repairs, take your watch off the charger and power it down.
Insert an opening tool into the gap between the back cover and the watch case at the bottom edge of the back cover.
Use the opening tool to pry up the back cover of the Huawei Watch 2.
Carefully fold the back cover assembly to the opposite side of the two watch crowns.
To reassemble your Huawei Watch 2, follow these instructions in reverse order.
3 участников успешно повторили данное руководство.
3 Комментариев
Tengo un problema con el reloj que no me esta haciendo las mediciones de la frecuencia cardiaca, como se cambia y donde se consigue ese sensor.
Gracias
A carcaça do meu HUAWEI WATCH 2 quebrou aonde o pino da pulseira encaixa. Como conseguir uma para reposição? Grato.
