Введение
This guide will show how to replace the mechanical key switch LEDs from your HyperX Alloy Origins mechanical keyboard (serial number HX-KB6RDX and its variants).
The HyperX Alloy Origins mechanical keyboard provides RGB lighting to each of its keys through switch-mounted LEDs. Therefore, it is necessary to remove an entire key switch whenever its corresponding LED needs to be replaced.
Before beginning LED replacement, be sure to visit the troubleshooting page before making permanent changes to the PCB! This guide should only be used in the event that one or more keys do not light up while the remaining key LEDs are properly functioning.
Usage of a desoldering iron or a desoldering pump (alongside a normal soldering iron) is strongly recommended. The HyperX key switches contain pins which make it difficult to wick away solder. This guide uses a sole soldering iron for demonstration purposes only.
Выберете то, что вам нужно
Locate the toggle indicator tab on the top right corner of the keyboard.
Insert the metal spudger or some other separating instrument into the right crevasse between the tab and the keyboard.
Lift up gently on the tab, while holding the left side of the tab down.
Remove all Philips #0 screws from the new openings created after removing the rubber feet and plastic tab.
Identify the key switch to be replaced.
Remove its keycap by carefully prying it off of the keyboard with your fingers.
Flip the keyboard over to face the PCB.
Identify the corresponding switch to be removed.
Инструмент, используемый на этом этапе:Desoldering Pump$3.99
Melt the solder surrounding the four pins of the switch's LED, and the two lower pins of the switch body.
To remove the melted solder, use a desoldering iron, a desoldering pump, or desoldering braid.
Using a spudger or another metallic instrument, firmly press down upon the exposed plastic of the switch. This will separate the switch from the rest of the keyboard.
To reassemble your device, follow these instructions in reverse order. Note that when reattaching the switch back to the keyboard PCB, the switch needs to be held in place behind the keyboard while soldering.
