Ibanez Guitar Neck and Bridge Pickups Replacement
Выберете то, что вам нужно
  1. Ibanez Guitar Neck and Bridge Pickups Replacement, Neck and Bridge Pickups: шаг 1, изображение 1 из 2 Ibanez Guitar Neck and Bridge Pickups Replacement, Neck and Bridge Pickups: шаг 1, изображение 2 из 2
    • Turn the tuning pegs in a counterclockwise direction to loosen the strings.
    • Pull the strings from the tuning pegs and thread them out the back of the guitar.
  2. Ibanez Guitar Neck and Bridge Pickups Replacement: шаг 2, изображение 1 из 1
    • Use a soft cloth or a guitar cleaning kit to wipe down the body, neck, and fretboard.
  3. Ibanez Guitar Neck and Bridge Pickups Replacement: шаг 3, изображение 1 из 2 Ibanez Guitar Neck and Bridge Pickups Replacement: шаг 3, изображение 2 из 2
    • Use the screwdriver to loosen each screw on the pickguard.
    • Remove knobs and pickup selector switch.
    • These knobs can be very tough to remove. If you feel like you may damage them by forcing them off, just leave them on.
  4. Ibanez Guitar Neck and Bridge Pickups Replacement: шаг 4, изображение 1 из 1
    • Remove the old pickups from the guitar body.
  5. Ibanez Guitar Neck and Bridge Pickups Replacement: шаг 5, изображение 1 из 2 Ibanez Guitar Neck and Bridge Pickups Replacement: шаг 5, изображение 2 из 2
    • Desolder connections from both red and green wire bundles.
    • There should be three separate wires per bundle that need to be individually removed.
    • For soldering help, visit this guide.
  6. Ibanez Guitar Neck and Bridge Pickups Replacement: шаг 6, изображение 1 из 2 Ibanez Guitar Neck and Bridge Pickups Replacement: шаг 6, изображение 2 из 2
    • Solder the new pickup wires to your control board.
    • Place your new pickups in the guitar body.
    • We highly recommend having a manual pertaining to your specific pickups. It will show you where each specific wire needs to be attached.
  7. Ibanez Guitar Neck and Bridge Pickups Replacement: шаг 7, изображение 1 из 1
    • Use the screwdriver to reinstall pickguard screws.
    • Re-attach pickup selector and knobs.
    • Not all screw locations are visible in the image. Make sure to use all of them.
  8. Ibanez Guitar Neck and Bridge Pickups Replacement: шаг 8, изображение 1 из 2 Ibanez Guitar Neck and Bridge Pickups Replacement: шаг 8, изображение 2 из 2
    • Thread your new strings through the back of the guitar, up to the tuning pegs, and tighten the strings.
    • Use the wire cutters to trim excess string from the ends.
Финишная черта
Joe Torres
Участник с: 02/21/23
157 Репутация
1 руководство автора
Команда
University of North Texas, Team 2-12, Raign Spring 2023 Участник University of North Texas, Team 2-12, Raign Spring 2023
UNT-RAIGN-S23S2G12
2 членов
Автор 1 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 55
За всё время: 639
