Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Flip the projector right-side up and turn it so that the back ports are facing you.
Remove the 7 mm metallic screws using the flat-head screwdriver.
Using the T10 Torx screwdriver, remove the two black 10 mm screws located at the center of the back panel.
Flip the projector over.
Use the T10 Torx screwdriver head to remove the two 77mm screws located nearest to the back panel ports.
Remove the two 10mm screws located near the lens side with the T10 Torx screwdriver head.
Flip the projector back over.
Unplug the speaker wire from the circuit board by simultaneously squeezing the sides and pulling.
Pull on the brown tabs located at the sides of the white plastic ribbon holder and pull the ribbon out.
Remove the top cover.
Hold down the release tabs to remove the cables from the white tabs.
Use the T10 Torx screwdriver to remove the five 5mm screws located throughout the motherboard.
Pull up the five metal tabs located at the rear of the projector.
Remove the three gold ribbons by flipping up the black taps that hold the ribbon in place.
Pull the ribbons out carefully and place them under the main board.
Carefully lift the entire main board up.
Еще один человек закончил это руководство.
