Введение
Remove sections of pipe for inspection, repair, replacement, or to gain access to the pump cylinder.
Выберете то, что вам нужно
Pull the pump handle all the way down and hold it in this position, exposing the pump rod.
Place the spacer around the pump rod and under the chain attachment point.
Lift the pump lever until there is no tension in the chain and hold it in this position.
Remove the bolt connecting the chain to the pump handle.
Remove the chain from the handle.
There are 4 bolts securing the head section to the water tank, located at the corners of head section base.
Remove the 4 bolts on the base of the water tank.
Lift the pump head off of the water tank and place in a sanitary place, preferably above ground, to prevent contamination.
Lift the plunger assembly and separator plate and place a rod clamp below the separator plate.
Tighten the rod clamp and gently set the separator plate on top of it.
Remove the spacer.
Hold the rod clamp steady while removing the chain from the pump rod. Check the chain for signs of damage.
Remove the lock nut by turning it counterclockwise.
Remove the separator plate.
Reinstall the lock nut.
Install a T-handle, screwing it down against the lock nut.
Lift up on the T-handle to take pressure off the rod clamp.
Remove the rod clamp and slowly lower the T-handle.
There are 4 bolts securing the water tank to the pump base. They are located at the bottom corners of the water tank.
Lift the water tank up approximately 1 foot.
Place a base clamp around the exposed pipe and tighten it against the riser main.
Secure the base clamp to the pump base with two bolt and nut sets installed on opposite sides of each other.
Turn the water tank counterclockwise until it comes free from the pipe.
Lift the water tank up against the T-handle and secure the rod clamp to the pump rod.
Remove the T-handle.
Remove the water tank and check for signs of blockage.
Store in a sanitary place to prevent contamination.
Place a pipe coupler over the pump rod.
Install the T-handle onto the pump rod.
Loosen and remove the rod clamp.
Screw the pipe coupling onto the threaded riser main end and slowly lower the T-handle.
Have two people place C wrenches on the riser main on opposite sides of each other.
Have the two people with C-wrenches apply light upward pressure to the riser main while the base clamp operator loosens the clamp.
Lift the pipe evenly, not exceeding the comfortable lifting height of either lifter. Re-secure the base clamp once the maximum lifting height has been reached.
Lower the C-wrenches and repeat this step until the pipe coupling reaches the base clamp.
When you reach the pipe coupling, open the clamp more to allow it to pass through. Lift the riser main approximately one foot above the clamp and re-secure the pipe.
Place one pipe wrench on the exposed coupling and another on the riser main above the coupling. Have a third person stabilize the upper pipe.
Hold the wrench on the coupling steady while the wrench on the riser main is rotated counterclockwise until the pipe comes free.
Lift the upper pipe and place the rod clamp onto the pump rod below the pump rod coupling.
Lift and hold the upper pipe high enough to expose the pump rod coupling.
Place one open end wrench over the lower portion of the pump rod coupling. Hold this wrench steady.
Place another wrench on the upper portion of the pump rod coupling. Turn this wrench counterclockwise until the coupling separates.
Pull the upper pipe away from the pump and lay it on its side away from the pump.
Remove the T-handle from the pump rod.
Install the T-handle on the pump rod still in the well.
Gently lower the T-handle.
Repeat steps 18 through 23 until you reach the pump cylinder.
