Выберете то, что вам нужно
Using the plastic opening tool, remove screen protector from front of monitor.
Remove the six 4mm screws using a Phillips #00 screwdriver.
Remove the screen, exposing the circuit board.
Turn device over to expose rear circuit board.
Unscrew the four 3 mm screws holding the motherboard to the unit using a Phillips #00 screwdriver.
Flip the device over, and de-solder the defective charging port using the soldering iron.
Еще один человек закончил это руководство.
2 Комментариев
I appreciate you posting this. What kind of new charging port did you use (USB type, size, etc) and does IFIXIT sell them?
The part you are looking for is a female Micro USB B-Type solder socket. I no longer have the unit available to confirm, but I'll bet you could contact Infant Optics and confirm with them. Sorry I can't be of more help!
