Введение
If the monitor of the Infant Optics DXR-8 is not functioning properly, the motherboard may be faulty. Follow these instructions to replace the motherboard in the monitor.
Выберете то, что вам нужно
Using the plastic opening tool, remove screen protector from front of monitor.
Remove the six 4mm screws using a Phillips #00 screwdriver.
Remove the screen, exposing the circuit board.
Turn device over to expose rear circuit board.
Using a plastic opening tool, disconnect the ribbon cable connector.
Gently separate the ribbon cable from the motherboard.
Using a Phillips #000 screwdriver, remove the four 4mm screws around the edge of the motherboard.
Flip the motherboard away from the front case to reveal the screen on the other side.
Using a plastic opening tool, carefully pry the top retaining frame off of the screen. Start in one corner and work around the bottom of the frame.
Using a plastic opening pick, carefully pry a corner of the screen away from the motherboard.
Lift the screen off of the motherboard.
Flip the motherboard away from the case.
Using a soldering iron and desoldering braid, desolder the antenna from the motherboard.
Еще один человек закончил это руководство.
2 Комментариев
Can you please tell me where to buy a replacement motherboard??
