Infinity v2 10.1 Battery Replacement
Выберете то, что вам нужно
  1. Infinity v2 10.1 Battery Replacement, Back Case: шаг 1, изображение 1 из 3 Infinity v2 10.1 Battery Replacement, Back Case: шаг 1, изображение 2 из 3 Infinity v2 10.1 Battery Replacement, Back Case: шаг 1, изображение 3 из 3
    • Slightly pry open one corner of the device by using your finger nail to separate the screen from the back case.
    • Use an opening tool to carefully detach the back case from the tablet. Start by inserting the tool where your fingernail opened a gap, and work around all four sides of the device.
    • There will be a slight click noise as you free each tab.
    • Once the case is completely free, carefully lift it and place it face up on the workstation, being cautious not to damage the speaker wires connecting the two halves.
  2. Infinity v2 10.1 Battery Replacement: шаг 2, изображение 1 из 2 Infinity v2 10.1 Battery Replacement: шаг 2, изображение 2 из 2
    • Remove the speakers from the case by gently lifting them up and out of their slots.
  3. Infinity v2 10.1 Battery Replacement, Battery: шаг 3, изображение 1 из 3 Infinity v2 10.1 Battery Replacement, Battery: шаг 3, изображение 2 из 3 Infinity v2 10.1 Battery Replacement, Battery: шаг 3, изображение 3 из 3
    • Pry beneath each side of the battery using a spudger.
    • The adhesive may be too strong to manually remove, so heat can be applied using the iOpener. This evenly heats the adhesive and allows the battery to be lifted away easier. Do not place the iOpener directly on the battery; always apply heat on the opposite side of the device.
    • You may use a blow-dryer on a cool setting. Keep the dryer moving and at least 6 inches from the battery to prevent dangerous bubbling of the battery due to excess heat.
  4. Infinity v2 10.1 Battery Replacement: шаг 4, изображение 1 из 2 Infinity v2 10.1 Battery Replacement: шаг 4, изображение 2 из 2
    • Desolder the red and black wires connecting the battery to the motherboard.
    • Once the solder is melted, use tweezers to remove both wires from the motherboard.
    • The solder and iron will be extremely hot. Use tweezers to grab the wire to avoid burning your fingers from accidental contact with the iron.
Заключение
Еще один человек закончил это руководство.
Nate Rice
Участник с: 10/31/19
321 Репутация
Автор 3 руководств
Команда
UMass Dartmouth, Team S2-G4, Barthe Fall 2019 Участник UMass Dartmouth, Team S2-G4, Barthe Fall 2019
UMASSD-BARTHE-F19S2G4
3 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 12
За всё время: 332
