Введение
If your tablet display is not functioning or the image is distorted, you may need to replace the screen.
Выберете то, что вам нужно
Use a plastic opening tool to remove the rear panel from the front case.
Insert the plastic opening tool between the front case and rear panel. Use a prying motion to lift the front case from the rear panel.
Work the tool around the perimeter of the device until the front and rear panels become separate.
Use tweezers to remove the gray pieces located around the speakers and four screws that were removed in the previous step.
Use a plastic opening tool to flip up the ribbon cable connector that connects the camera to the motherboard.
Use a plastic opening tool to flip the ribbon connector up in order to free the ribbon cable from the motherboard.
Free the battery from the motherboard by desoldering the red, white, and black connections one by one.
For soldering instructions, visit this guide.
Use a plastic opening tool or spudger to remove the battery from the front case.
Place the plastic opening tool between the battery and front case. Work the tool around the perimeter of the battery until the battery is free.
Use tweezers to free the twisted, red and black wire from the three clips on the front case.
Remove the speakers from the tablet by gently pulling the yellow tape up from the front case.
Use a plastic opening tool to flip up the ribbon cable connectors that connect the touch digitizer to the motherboard.
Gently lift the gray mesh tape up that holds the motherboard down to the front case.
Lift the motherboard up from the front case.
Peel away the grey mesh tape that holds down the touch digitizer's ribbon cable to the front case.
Use a plastic opening tool to separate the front case from the LCD screen.
Insert the plastic opening tool between the front case and rear LCD screen. Use a prying motion to lift the LCD screen from the front case.
Use a plastic opening tool to flip up the last ribbon cable on the screen.
Free the ribbon cable from the LCD screen.
