Введение
This guide will provide you with step by step instructions on how to replace the speakers inside the device. This replacement should only be required for faulty speakers.
Выберете то, что вам нужно
Place the device on a firm surface with the device screen facing down.
Инструмент, используемый на этом этапе:Plastic Cards$2.99
Using a plastic tool and the plastic card, gently pry off the back cover.
Using tweezers, remove the electrical connector that connects to the battery to remove the power to the battery.
Remove 2 electrical connectors that connects to the speaker using flat tweezers.
