Введение
Welcome to the Insignia Flex 8 repair guide. If your battery is not holding a charge, use this guide to fix it. This replacement is simple and only requires a prying tool and soldering gun.
Выберете то, что вам нужно
Position the tablet so that the screen is face down.
Hold the power button for three seconds until the tablet powers down.
Remove the back casing by sliding a credit card or a similarly thin but firm object in between the casing and the screen.
Remove the back casing and set aside.
Slide the spudger beneath battery to pry away it away from the case. Work around the battery, prying up all edges to remove from glue.
Desolder the black, yellow and red connections from circuit board. Desoldering Help
4 участников успешно повторили данное руководство.
