JBL Charge 3 Port Bay Replacement
Выберете то, что вам нужно
  1. JBL Charge 3 Port Bay Replacement, Front Cover: шаг 1, изображение 1 из 3 JBL Charge 3 Port Bay Replacement, Front Cover: шаг 1, изображение 2 из 3 JBL Charge 3 Port Bay Replacement, Front Cover: шаг 1, изображение 3 из 3
    • Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
    • Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
    • Repeat this process for all four edges of the front cover.
    Sometimes disassemblers forget that the first time they disassembled the item it didn’t want to give up easily: I didn’t like the forces I was having to apply at all, so I switched to two plastic prying tools per “corner” and one in-between them (total 5, you could use plectrums…) before I was happy the the forces were low enough not to break anything.
    Frank Puranik - Ответить
    the front grill is supposed to be first not the back the back has longer while the front has shorter clip
    Water Bass Tester (Water BT) - Ответить
    There are two Phillips head screws to remove before prying the cover off
    jason - Ответить
    Where in south Africa can I buy jbl charge3 port bay replacement
    Donovan Fransman - Ответить
    There appears to be different versions of the Charge 3. If you find it difficult to pry open a second side the two small screws mentioned by Jason will need to be removed but it also indicates that there will be some additional changes to this tear down that I will try to convey in the comments as well.
    john Ramirez - Ответить
    Sadly I damaged the latches on my charge 3. There was more to it than just prying the front cover up. First, there is a small latch on both sides that you need to push down before pulling the front cover towards you that release the clips holding the front cover in place. Pull only slightly forward because… Second, in the front cover there are 6 circular notches connected to the front cover in tue four corners including the middle corners, you need to squeeze the front cover a little bit gently removing the notches so they dont break (like mine did).
    ralphkeneth_gomz - Ответить
    Definitely had to watch about 10 videos and still couldn’t get it to pop out easily.. Took a look at the first picture in the next step and really took note of where the little hole that lets you through to push down the tab is. Once I took a look at that and combined the techniques I’d seen in some of the videos it finally popped off easily. https://www.youtube.com/watch?v=u7i0_nD9... I only watched the first minute of this video but it helped a good bit if anyone else is having trouble.
    Rowan Darko - Ответить
    How do you know if the speakers or one of them is burned or broken.. i notice that one speaker is playing much less hard then the other one.. I wonder now if maybe there is another problem with my device.. Battery problem?
    Bukowski101 - Ответить
  2. JBL Charge 3 Port Bay Replacement: шаг 2, изображение 1 из 1
    • Pull apart your cover gently from both sides and remove it from the speaker housing.
    • There are screws around the foot of the device that may need loosening to be able to unclip the other side of the cover.
    • The inside of the front cover has holes that must match with their corresponding pins on the speaker housing for proper reassembly.
    • Removing the Front Cover does not affect the waterproof seals of the device. However, removing any further disassembly of your speaker will require removing waterproof seals and gaskets. Your device may no longer be waterproof after these have been altered.
    Include dissembling the plastic cover? cover?
    KanGoon - Ответить
    @KanGoon Yes, on mine it took the removal of 6 (reasonably obvious) screws to remove that. I’ll try to insert a photo when I reassemble…
    Very good guide! Pics and descriptions make this easy!
    John G Petko - Ответить
    There is a step missing here. How do you remove the rubber cover that covers the port?
    Phillip Luebke - Ответить
    Gibt es eine Möglichkeit diese wieder wasserdicht zu bekommen?
    Furkan Karakelle - Ответить
    Well, broke off the cover tabs. Have to remove 2 screws first. Might add that to the instructions.🤔
    Spartacus - Ответить
    Me too. Saw the screws after I'd popped it off.
    Del Taylor -
    It doesn't look fixable. Can't get the cover to stay on anymore. Ideas?
    Del Taylor - Ответить
  3. JBL Charge 3 Port Bay Replacement, Port Bay: шаг 3, изображение 1 из 3 JBL Charge 3 Port Bay Replacement, Port Bay: шаг 3, изображение 2 из 3 JBL Charge 3 Port Bay Replacement, Port Bay: шаг 3, изображение 3 из 3
    • Take out the four 8mm Phillips #1 screws out of the port bay cover.
    • Wedge your plastic opening tool around the port bay to remove it.
    and then wiggle it directly (almost radially from the cylinder) out until you see the cables shown in the next step.
    Be careful not to damage the plastic gasket as you pull it out,
  4. JBL Charge 3 Port Bay Replacement: шаг 4, изображение 1 из 3 JBL Charge 3 Port Bay Replacement: шаг 4, изображение 2 из 3 JBL Charge 3 Port Bay Replacement: шаг 4, изображение 3 из 3
    • Disconnect the two bundled cable connector from the port bay.
    there’s not much room to get you fingers in. Again I used prying tools to help me get the two connectors off the PCB
    How do i get another port bay
    pjimenez98 - Ответить
  5. JBL Charge 3 Port Bay Replacement: шаг 5, изображение 1 из 3 JBL Charge 3 Port Bay Replacement: шаг 5, изображение 2 из 3 JBL Charge 3 Port Bay Replacement: шаг 5, изображение 3 из 3
    • Remove the three 8mm Phillips #1 screws from the port bay circuit board.
    • Pull the port bay cover off of the circuit board.
    Be careful not to break the 2 plastic lugs you can see just below (on the photo) the 2 screws at the edges
  6. JBL Charge 3 Port Bay Replacement: шаг 6, изображение 1 из 2 JBL Charge 3 Port Bay Replacement: шаг 6, изображение 2 из 2
    • Desolder the USB, MicroUSB, or AUX port off of the circuit board.
    Salve, dove posso ordinare la presa usb piccola di ricarica, c’è un sito apposito?
    Robert James Hanrahan - Ответить
Заключение
38 человек успешно провели ремонт по этому руководству.
Jack Ng
Участник с: 10/08/18
2 228 Репутация
Автор 4 руководств
Команду
Cal Poly, Team S1-G6, Zimmerman Spring 2020 Участник Cal Poly, Team S1-G6, Zimmerman Spring 2020
CPSU-ZIMMERMAN-S20S1G6
4 членов
Автор 27 руководств
16Комментарии к руководству
Is there a place to buy an entire replacement port bay?
indecisive_decision - Ответить
Found the whole assembly on line for 30 bucks. Or a usb port for five from jbl
bonnie.1964 - Ответить
Can u share a link? Need a new port bay!
Max de Groot -
Hello! My jbl charge 3 has a problem in bluetooth, I can't detect the bluetooth in any gadget. Is there anybody have an idea how to fix this?
ebataluna - Ответить
anyone have the charging ways of this board i have 2 pads missing and would like to run the lines
Juju B - Ответить
yeah i need that too. the micro usb broke off the mb
Benjamin Goerke -
Hi,
the pinout for the micro-usb socket, looking from the top side (3.5mm audio socket is on my left and USB port is on my right):
1. Most left line, line #1 on the micro-usb connector is GND. Goes to the pin #5 (also connected to #6 and #7) of the large 11pin connector labeled J602.
2. Line #2 on the micro-usb connector is ID which is connected to the GND - pin #5 (also connected to #6 and #7) of the large 11pin connector labeled J602.
3. Line #3 on the micro-usb connector is DATA +, which goes to pin #4 of the large 11pin connector labeled J602.
4. Line #4 on the micro-usb connector is DATA -, which goes to pin #3 of the large 11pin connector labeled J602.
5. Line #5 (most right) on the micro-usb connector is VCC/+5V, which goes to pin #1 (also connected to #2) of the large 11pin connector labeled J602.
Simon -
I have the same problem
Jakob -
Welche Maße haben die Ladebuchsen?
Jan Philipp - Ответить
Hi,
for anyone interested - we are offering the micro-usb socket replacement service for JBL Charge 3.
You can google “getgui charge 3 micro-usb” since its probably against the policy to post links here.
Simon
Simon - Ответить
Where can I buy the port bay
martinezjajlj - Ответить
Wo kann man bauteile bestellen ? Bitte Antwort.
manuel.hill - Ответить
does anyone know where i can buy a new charging port board
neohunter - Ответить
Habe heute die SMD Micro USB Ladebuchse ausgetauscht. Wie man diese Reparatur in 15min erledigen will ist mir ein Rätzel. Und einfach eine THT und SMD Buchse umlöten, benötigt wirklich Fachwissen und die nötigen Lötskills. Eher 30 bis 45 minuten mit dem richtigen Werkzeug und Microskop!
Yoshioiram - Ответить
Ersatzteil:
✅ JBL Charge 3 Bluetooth Lautsprecher Micro USB DC Buchse Ladebuchse Connector
https://www.ebay.de/itm/163349223128
Falls Sie beim Austausch der Buchse Hilfe benötigen:
✅ REPARATUR Austausch Micro USB Ladebuchse JBL Charge 3 Bluetooth Lautsprecher
https://www.ebay.de/itm/163349231063
PC-Solutions - Ответить
This is incomplete repair directions. Putting the new connector on the board poses some issues. what about the pins on the back/bottom of the connector? how did you attach those to the board? Complete the repair!
adam724 - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 18
За последние 7 дней: 144
За последние 30 дней: 538
За всё время: 63,835
