Введение
This guide will focus on removing the microphone.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Tweezers$3.99
Use the angled tweezers to carefully pull the rubber bumper off the back side of the device
There will be three 6mm philips head screws under that rubber bumper, remove these three screws.
The battery is adhered to the back cover of the JBL Clip Plus, slowly lift the battery away from the case, using a spudger to pry the battery away from the adhesive.
Use the plastic prying tool to gently remove the face of the speaker from the body.
Use the spudger tool to gently scrape away the adhesive holding in the microphone.
Gently push the motherboard away from the microphone, this will allow you to remove the microphone.
Gently push the motherboard out from the frame of the JBL Clip Plus, this requires some force.
There are three solder points that need to be desoldered.
If you need help with desoldering refer to How to Solder and Desolder Connections help. After these are removed the battery should be free.
Use a desolder tool to remove the solder to the microphone.
If you are unsure how to desolder these connections, refer to How To Solder and Desolder Connections
Еще один человек закончил это руководство.
Один комментарий
Love the sound of this speaker but I would like to disable the bluetooth signals. I only need and use the cable connection. I have contacted the manufacturer about this and they said the bluetooth cannot be disabled at the present set-up. Would you please show me how to disable or remove the bluetooth?
