Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Within this guide, the user will learn how to separate the two sides of the JBL Flip 2 Speaker. The user will disconnect everything in order to safely work on the internal components.
Выберете то, что вам нужно
Begin by removing the rubber caps on both sides of the JBL Flip 2 by using the black spudger to get in between the creases.
The NFC chip is glued onto the side of the device. Use the black spudger to separate the mic from the surface.
Gently slide the NFC chip into the device through the slot that the wire comes from.
Remove the two 7.0 mm Phillips #1 screws.
Carefully detach the silver plastic cover by pulling both ends off.
Separate the silver plastic piece by pulling it off from the middle.
Using a flat-head screwdriver or spudger, pry out the 8 metal nibs on the back side of the speaker.
Repeat the same process for the 4 remaining metal nibs (two on each end).
Using the driver adapter, first insert the #4 socket into the driver; followed by the #1 Philip's head bit in order to reach the three 13.0 mm screws.
Using the classic spudger, get underneath the black tape strips found on both side of the device.
After lifting a portion of the tape off of the device, gently peel the tape off of the device, making sure to keep it intact.
There is another piece of tape on the side of the device with the control buttons. Lift the tape with the classic spudger and then peel the rest of the tape off.
Wedge a spudger between the two halves where the tape was to pry the device open.
Using the black spudger, carefully remove the cord connecting the battery to the motherboard.
