Введение
If the lights on the board aren’t working, the buttons on aren’t responsive, or Bluetooth is no longer functioning correctly, you may need to replace the motherboard. This guide will give you step-by-step instructions on how to replace the motherboard on the Jabra Speak 510.
Выберете то, что вам нужно
Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws.
Use a small, pointed metal spudger to release the plastic tabs connecting the faceplate to the bottom of the speaker.
Slowly flip the device open like a clam shell.
After removing the screws, take out the center covering to free the motherboard by lifting the tabs and pulling it off.
Peel off the white adhesive to desolder the connections underneath.
Desolder the wires connected to the motherboard.
4 участников успешно повторили данное руководство.
3 Комментариев
Great walk-through... thanks
Be very careful when desoldering the connector cables! The soldering lugs are poor quality and tend to tear off the PCB
