Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Press on tab while pulling up on K-cup until you hear a click. Repeat for the remaining tabs. We found using the smallest of the "plastic opening tools" worked wonders.
Once all of the tabs have been pressed, the K-Cup should just pop out. After, you just pull the remainder of the K-Cup. You have successfully removed the K-Cup.
Remove two 9 mm Phillips #1 screws.
The screws are located on the top of where the K-Cup would be.
Once you remove the screws, the top cover should come out.
You will then want to remove these screws which are the same size.
Once you get those removed, you are going to want to pull on the hose until it pops off.
Once the hose comes off, the needle will fall out by itself.
2 участников успешно повторили данное руководство.
Один комментарий
Where do you buy the needle I know you can get the exit needle with the holder, but can’t find this one.
