Введение
  1. Front and Back view of camera. Use a Philips Head screw driver to unscrew the sides of the camera. There are six screws total. Front and Back view of camera. Use a Philips Head screw driver to unscrew the sides of the camera. There are six screws total.
    • Front and Back view of camera. Use a Philips Head screw driver to unscrew the sides of the camera. There are six screws total.
  2. Use a Philips Head screw driver to unscrew the sides of the camera. There are two screws on each side except for the top of the camera. Carefully remove face plate of camera. Place alongside near screws. Use a Philips Head screw driver to unscrew the sides of the camera. There are two screws on each side except for the top of the camera. Carefully remove face plate of camera. Place alongside near screws.
    • Use a Philips Head screw driver to unscrew the sides of the camera. There are two screws on each side except for the top of the camera. Carefully remove face plate of camera. Place alongside near screws.
  3. To get to control buttons, use a Phillips Head screw driver to unscrew the three screws near lens. To get to control buttons, use a Phillips Head screw driver to unscrew the three screws near lens. To get to control buttons, use a Phillips Head screw driver to unscrew the three screws near lens.
    • To get to control buttons, use a Phillips Head screw driver to unscrew the three screws near lens.
  4. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  5. Unscrew the screw near the rechargeable battery compartment. The metal piece then can be removed. Unscrew the screw near the rechargeable battery compartment. The metal piece then can be removed. Unscrew the screw near the rechargeable battery compartment. The metal piece then can be removed.
    • Unscrew the screw near the rechargeable battery compartment. The metal piece then can be removed.
  6. Remove additional screws near lens. Remove additional screws near lens.
    • Remove additional screws near lens.
  7. This is what the camera should look like with all screws are removed. Flip camera over to carefully remove the screen cover. This is what the camera should look like with all screws are removed. Flip camera over to carefully remove the screen cover.
    • This is what the camera should look like with all screws are removed. Flip camera over to carefully remove the screen cover.
  8. Remove buttons from back case of screen cover. Replace with new set of buttons. Remove buttons from back case of screen cover. Replace with new set of buttons.
    • Remove buttons from back case of screen cover. Replace with new set of buttons.
  9. Follow the steps in reverse order to reassemble the camera. Now you can take beautiful pictures again!
    • Follow the steps in reverse order to reassemble the camera. Now you can take beautiful pictures again!
Заключение
Once you purchase these parts, follow the given instructions. To reassemble your device, follow these instructions in reverse order.
3 участников успешно повторили данное руководство.
Elizabeth
Участник с: 28.01.2015
279 Репутация
Автор 2 руководств
Команда
Penn State, Team 1-2, Kaschak Winter 2015 Member of Penn State, Team 1-2, Kaschak Winter 2015
PSU-KASCHAK-W15S1G2
1 член
Автор 2 руководств
Один комментарий
como cambio la tapa de la bateria y pin de carga
Dario - Ответить
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 1
За всё время: 282
