Kurio 7 Battery Replacement
Выберете то, что вам нужно
  1. Kurio 7 Battery Replacement, Back Panel: шаг 1, изображение 1 из 3 Kurio 7 Battery Replacement, Back Panel: шаг 1, изображение 2 из 3 Kurio 7 Battery Replacement, Back Panel: шаг 1, изображение 3 из 3
    • Begin by removing the rubber cover from the Kurio 7.
  2. Kurio 7 Battery Replacement: шаг 2, изображение 1 из 2 Kurio 7 Battery Replacement: шаг 2, изображение 2 из 2
    • Remove the four 30 mm Phillips #00 screws from the outer case.
  3. Kurio 7 Battery Replacement: шаг 3, изображение 1 из 2 Kurio 7 Battery Replacement: шаг 3, изображение 2 из 2
    • Insert the plastic opening tool in the gap between the front cover and the back cover of the device.
    • Slide the plastic opening tool around the edge of the device. Gently pry apart the tabs that hold the front cover and the back cover together.
    • Be careful not to break off the tabs that hold the front cover and the back cover together.
  4. Kurio 7 Battery Replacement: шаг 4, изображение 1 из 2 Kurio 7 Battery Replacement: шаг 4, изображение 2 из 2
    • Once all of the tabs are removed, the back cover should come off easily.
    • Gently remove the back cover. There are wires inside that may get caught on the cover while removing it. These wires are soldered to their components and are difficult to reattach.
  5. Kurio 7 Battery Replacement, Battery: шаг 5, изображение 1 из 1
    • Use a credit card, or other thin object, to separate the battery from the screen.
    • Be sure to work the card slowly and carefully in order to not damage, break, or deform the battery.
  6. Kurio 7 Battery Replacement: шаг 6, изображение 1 из 1
    • Desolder, or separate using the desoldering braid, the marked areas on the motherboard to remove the old battery.
    • Refer to our soldering guide on how to solder and desolder.
Заключение
Solder in the new battery. To reassemble your device, follow these instructions in reverse order.
2 участников успешно повторили данное руководство.
Alex Powaser
Участник с: 04/14/14
331 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 12-36, Maness Spring 2014 Участник Cal Poly, Team 12-36, Maness Spring 2014
CPSU-MANESS-S14S12G36
4 членов
Автор 14 руководств
Один комментарий
Can the charging port be replaced in the kurio 7s tablet
Pamela Haughton - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 8
За последние 30 дней: 11
За всё время: 16,822
