Введение
Is the audio for your headphones distorted or not working? You will have to replace it. This will require you to solder so please refer to this guide to do so.
Выберете то, что вам нужно
Remove the tape from the edges of the battery and the small piece on the motherboard.
Remove the two 5mm screws from the mother board.
Remove the connectors by lifting the tabs and pulling gently.
Почти готово!
Заключение
