Введение
Does your tablet give out poor sound or does not give sound at all? It is probably time to change your speakers. Refer to this guide to learn how to change your speakers. This will require you to solder so use this guide to help.
Выберете то, что вам нужно
Use the Phillips #0 Screwdriver to remove four 5mm screws from sides of the device.
Use the Ifixit opening tool to pry open the device to remove the back of the Kurio Motion.
Use your soldering tool to solder the wires that are connected to the motherboard. There should be four wires.
