Введение
If you need to replace a component inside the LG G Pad 8.3, you will need to remove the back panel. This guide will teach you how to remove the back panel.
Выберете то, что вам нужно
With the tablet face down, pull the SD card slot cover out.
Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
Insert a plastic opening tool in the small crevasse between the screen and the back panel.
Pry the screen away from the back panel.
Repeat this on each edge of the device.
After using the plastic opening tools, pry the device open with your hands.
Remove the back panel from the screen.
