LG Grace Screen Replacement
Выберете то, что вам нужно
  1. LG Grace Screen Replacement, Phone Assembly: шаг 1, изображение 1 из 1
    • Find the indentation along the edge of the phone's back and pry open with your nail. A pry tool may help if you have short nails but shouldn't be necessary.
  2. LG Grace Screen Replacement: шаг 2, изображение 1 из 1
    • Pull the battery out of the back of the phone. A small indent is present to allow you to pry it out but you may also just flip the phone over and strike it gently against your palm.
  3. LG Grace Screen Replacement: шаг 3, изображение 1 из 2 LG Grace Screen Replacement: шаг 3, изображение 2 из 2
    • Unscrew all of the screws now visible on the back panel of the phone--11 in total. A #00 Phillips screwdriver works here.
    • The screws are M1.3 and 3 mm long.
  4. LG Grace Screen Replacement: шаг 4, изображение 1 из 2 LG Grace Screen Replacement: шаг 4, изображение 2 из 2
    • Insert the Jimmy into the small gap between the edge of the phone screen and body. Gently pry until it pops loose then remove jimmy and use your hands to slowly pry the body away from the screen
  5. LG Grace Screen Replacement, Rear Camera: шаг 5, изображение 1 из 1
    • Locate the pin connection for the camera, noted by red box in the guide photo.
    • Gently lift the camera up while pulling away from connection; it should detach with minimal effort.
  6. LG Grace Screen Replacement, Motherboard: шаг 6, изображение 1 из 1
    • Next we remove the front speaker from the motherboard, with the goal of removing all connections that hold the board in place.
    • The location of the speaker is highlighted in the guide photo.
    • Just like with the camera, gently pull the ribbon wire away from the connector and it should release easily.
  7. LG Grace Screen Replacement: шаг 7, изображение 1 из 1
    • There is also a ribbon cable connected to the board by the charging port, as highlighted in the photo.
    • Pull it away in the same fashion as the others, and now the motherboard should be free.
  8. LG Grace Screen Replacement: шаг 8, изображение 1 из 1
    • From here, you should be able to gently pull the motherboard away from the screen assembly and remove it. I recommend grabbing the edge by the port and lifting with one hand while holding the phone down with the other.
  9. LG Grace Screen Replacement, Screen: шаг 9, изображение 1 из 2 LG Grace Screen Replacement, Screen: шаг 9, изображение 2 из 2
    • Now we remove the audio jack. Place something long and thin in the jack and pry up to remove it from it's seating.
    • Use the Jimmy to slide under the connection to the screen assembly and pry it up and away.
  10. LG Grace Screen Replacement: шаг 10, изображение 1 из 1
    • Now we remove the side rocker buttons. To do this we place the jimmy along the inside of the buttons and pry up and away gently.
    • This is risky for the buttons, be gentle and if they appear to be bending, stop and try another angle.
  11. LG Grace Screen Replacement: шаг 11, изображение 1 из 1
    • Next we will remove the front speaker.
    • Place a jimmy underneath the small connection to the screen assembly, and pry away.
    • When it's disconnected, remove from the assembly.
  12. LG Grace Screen Replacement: шаг 12, изображение 1 из 1
    • Finally we remove the CMOS battery. After this the screen assembly shouldn't have any components left on it.
    • Use the jimmy or other prying tool to pry the battery up from the connection; it may be difficult but you should be able to find the right angle of approach. The jimmy is thin enough that I found it more effective.
    • The new screen assembly will have identical places to put all of the components you removed.
Заключение
Dylan Kent
Участник с: 09/09/23
679 Репутация
Автор 6 руководств
Команда
University of New Orleans, Team 4-3, McDonald Fall 2023 Участник University of New Orleans, Team 4-3, McDonald Fall 2023
UNO-MCDONALD-F23S4G3
3 членов
Автор 6 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 12
За всё время: 116
