Введение
This repair is to replace the screen on an LG Rebel. One might need to do this if the screen is cracked or unresponsive. If your screen is cracked be careful not to scratch yourself on the glass.
Выберете то, что вам нужно
Place the plastic opening tool into the indent on the side of the phone and lift the back off the device.
Put the plastic opening tool in at a downward angle and push it up so that the back pops off.
Using either your finger or the spudger, gently lift the metal clasps until they are no longer connected to the back of the phone.
Using the metal spudger, push gently under the edge of the screen. You will hear the sound of the screen disconnecting from the glue.
Run the metal spudger around the entire perimeter of the phone , making sure to fully disconnect it from the glue.
Place suction cup on the screen.
Gently pull the screen up until it is completely disconnected from the phone.
13 человек успешно провели ремонт по этому руководству.
3 Комментарии к руководству
Hey! Very helpful guide. I was just wondering if this works with replacing the digitizer and the screen, or is it just the screen? email ellym54@gmail.com, I would really appreciate the help!
How do you know if you need to replace the digitizer as well? This Lg Rebel4 was dropped & screen cracked in 2 places however everything still works fine? Im not sure what a digitizer does though. Please help me so i understand because i dont want to mess this up.
Thanks guys
Blackhatchic1@gmail.com
This is just to replace the glass panel over the actual display/digitizer, is it not?
If this is right, why does one need tom remove the back of the case and “undo the metal clips”?
What about gluing the new screen in? It DOES need glue, does it not? Otherwise, what seals it from the environment?
