Введение
The phone battery may be old, the CPU may be overloaded, the battery is no longer holding charge, and/or the device operating temperature is too hot. Try closing out unused apps, maintaining a safe operating temperature, and enabling power saver mode.
Before using this guide, make sure to review the LG V50 ThinQ troubleshooting page to ensure there are no other options to save your battery.
If the battery needs to be replaced, this guide will help you replace the battery for your LG V50 ThinQ android phone. Make sure the device is powered off before replacing the battery.
Выберете то, что вам нужно
Flip the phone over, so that the back of the phone is facing you.
Using an opening pick, pry open the back cover of the phone by moving the opening pick along all sides to reveal the internal components.
Disconnect the battery from the phone by removing the battery connection from the connector port.
Remove the battery by prying the underside of the battery and pulling upwards with the opening pick (shown in image 2).
3 участников успешно повторили данное руководство.
