Введение
This is a replacement of a large animal water nipple, this will provide them access to water without them making a huge mess. This guide has ten easy to follow steps to ensure the replacement is done properly.
Инструменты
Запчасти
Детали не указаны.
With an adjustable wrench, unscrew the nut on the inside located near the base on the backside of the nipple.
Fill the container slightly to ensure that there are no leaks. Tighten the washer or pull out to see if a crack has formed while replacing.
This is a leak in the seal.
If there is a leak try placing some more Teflon tape. If this does not fix the issue continue reading this step. If there is no longer a leak, move on.
Place and thread the nut on the inside of the container on the backside of the nipple.
