Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
With an adjustable wrench, unscrew the nut on the inside located near the base on the backside of the nipple.
Ensure there is no damage to the hole that needs to be patched.
Fill the container slightly to ensure that there are no leaks. Tighten the washer or pull out to see if a crack has formed while replacing.
This is a leak in the seal.
If there is a leak try placing some more Teflon tape. If this does not fix the issue continue reading this step. If there is no longer a leak, move on.
Place and thread the nut on the inside of the container on the backside of the nipple.
Finally, place the container in the designated place and fill completely.
