Lefant M210 Wheel Assembly Replacement
Выберете то, что вам нужно
  1. Lefant M210 Wheel Assembly Replacement, Brush: шаг 1, изображение 1 из 2 Lefant M210 Wheel Assembly Replacement, Brush: шаг 1, изображение 2 из 2
    • Turn off the Lefant M210 and disconnect it from the charging dock.
    • Flip the unit over so the bottom faces upward.
    • Locate the circular brush assemblies on the left and right sides of the underside.
    • Place the unit on a clean, flat surface to prevent scratching.
    Спросите у FixBot
    Добавить комментарий
  2. Lefant M210 Wheel Assembly Replacement: шаг 2, изображение 1 из 3 Lefant M210 Wheel Assembly Replacement: шаг 2, изображение 2 из 3 Lefant M210 Wheel Assembly Replacement: шаг 2, изображение 3 из 3
    • Insert the iFixit Opening Tool (or similar pry tool) under the circular edge of the brush assembly.
    • Apply gentle downward pressure on the opposite end of the tool to lever the brush component out of its housing.
    • Remove the brush assembly completely and set it aside.
    • If replacing both brush assemblies, repeat this process on the other side.
    • Avoid using excessive force, which may damage the mounting clips.
    Спросите у FixBot
    • Position the new brush assembly above the square mounting peg.
    • Align the square cavity on the bottom of the brush with the corresponding square peg in the vacuum housing.
    • Press down firmly on the brush assembly until you hear or feel it click into place.
    • Gently tug on the brush to verify it is securely seated.
    • The brush should sit flush with the housing and not move when pulled gently.
    Спросите у FixBot
  3. Lefant M210 Wheel Assembly Replacement, Wheel Assembly: шаг 4, изображение 1 из 1
    • Use a Phillips screwdriver to remove four screws near each wheel.
    Спросите у FixBot
  4. Lefant M210 Wheel Assembly Replacement: шаг 5, изображение 1 из 2 Lefant M210 Wheel Assembly Replacement: шаг 5, изображение 2 из 2
    • Remove the plastic cover next to each wheel.
    • Grip both sides of the wheel and pull upwards.
    • The wheels of the device require some force to remove.
    • Don't pull the wheels too hard as they are attached to cables and may be damaged if yanked.
    Спросите у FixBot
  5. Lefant M210 Wheel Assembly Replacement: шаг 6, изображение 1 из 3 Lefant M210 Wheel Assembly Replacement: шаг 6, изображение 2 из 3 Lefant M210 Wheel Assembly Replacement: шаг 6, изображение 3 из 3
    • Hold the wheel up and detach the connector to release it from the device.
    Спросите у FixBot
Заключение
Adrian pg
Участник с: 09/09/24
147 Репутация
1 руководство автора
Команда
CSU Los Angeles, Team 2-4, Kershman Fall 2024 Участник CSU Los Angeles, Team 2-4, Kershman Fall 2024
CSULA-KERSHMAN-F24S2G4
4 членов
Автор 9 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 7
За последние 7 дней: 40
За последние 30 дней: 131
За всё время: 1,794
