Введение
The motherboard connects all the components of the toy pad to allow the device to function properly. The motherboard may need to be replaced if the toy pad is not working. This guide will show how to remove the motherboard.
Выберете то, что вам нужно
Use the metal spudger to gently pry open the corners of the top cover.
Pull the white connector away from the motherboard, keeping the white connector parallel to the board.
Remove the USB cable from the toy pad.
Pull the black connector of the ribbon away from the LED chip, keeping the connector parallel to the board.
Disconnect the connector on the other LED chip as well, if replacing both LED chips or the motherboard
Pull the ribbon away from the black connector of the LED chips.
Disconnect the ribbon from the other LED chip as well, if replacing both LED chips or the motherboard.
Lift up both LED chips. As you are lifting, pull towards the motherboard to release it from the toy pad cover.
Lift up the motherboard, and remove the motherboard and LED chips from the toy pad.
Flip the motherboard and LED chips over.
Desolder the LED chip from the motherboard.
Desolder both LED chips, if replacing both LED chips or the motherboard
Separate the LED chip(s) from the motherboard.
