Введение
This guide will show you how to replace the motherboard in the Lenovo 500e 2nd Gen Chromebook, model number: 81MC005AUS. The motherboard is essentially the brains of the laptop. It has many key components that make the device work properly. If the device is having trouble starting, then refer to our troubleshooting page.
Выберете то, что вам нужно
Remove nine 6 mm screws from the bottom cover of the laptop using a Phillips #0 screwdriver.
Go along the edge of the back panel with an iFixit opening tool until it pops loose.
Remove the back panel from the laptop.
Remove the three 4 mm screws (six total) from the left and right side brackets using a Phillips #00 screwdriver.
Gently remove the metal brackets from the motherboard.
Remove the nine 4 mm screws from the motherboard using a Phillips #00 screwdriver.
Remove the single 3 mm screw that holds the Wi-Fi card in place using a Phillips #00 screwdriver.
Using an iFixit opening tool, detach the speaker wiring from the motherboard.
Set speakers aside for reinstallation.
Using an iFixit opening tool, detach the track pad connector from the motherboard.
