Введение
Use this guide to replace the facility fan in your Lenovo IdeaPad 3-15ADA05. Before using this guide, be sure to review the troubleshooting page to ensure the fan is the problem. If the computer was recently used, give it 5 to 10 minutes to cool down.
Выберете то, что вам нужно
Remove the six M2 x 5mm screws located at the top half of the laptop using a #0 Phillips head, then remove the four M2 x 2.5mm screws located at the bottom of the laptop using a #0 Phillips head.
Inset the opening pick between the base plate and the bottom of the laptop and pry the clips loose around the edge until the base pops off.
Remove the two M2 x 3.30mm screws using the #0 screw head, then remove the one M2 x 5mm screw using the #0 screw head.
Disconnect the black and white antenna cables from the wireless card using the opening tool.
Еще один человек закончил это руководство.
