Lenovo IdeaPad Flex 4-1470 Battery Replacement
Выберете то, что вам нужно
  1. Lenovo IdeaPad Flex 4-1470 Battery Replacement, Lower Case: шаг 1, изображение 1 из 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Battery Replacement: шаг 2, изображение 1 из 2 Lenovo IdeaPad Flex 4-1470 Battery Replacement: шаг 2, изображение 2 из 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Battery Replacement, Battery: шаг 3, изображение 1 из 2 Lenovo IdeaPad Flex 4-1470 Battery Replacement, Battery: шаг 3, изображение 2 из 2
    • Disconnect the battery connector by using a plastic pry tool or your fingers to push the cable right towards the battery.
    • Do not pry or push on the socket itself or you risk damaging the motherboard.
  4. Lenovo IdeaPad Flex 4-1470 Battery Replacement: шаг 4, изображение 1 из 1
    • Remove the three 4 mm Phillips #0 screws holding the battery in place.
  5. Lenovo IdeaPad Flex 4-1470 Battery Replacement: шаг 5, изображение 1 из 1
    • Lift the battery up and out of the laptop.
Заключение
9 участников успешно повторили данное руководство.
Demario Robinson
Участник с: 10/02/17
1 038 Репутация
Автор 4 руководств
Команда
USF Tampa, Team S1-G6, Thompson Fall 2017 Участник USF Tampa, Team S1-G6, Thompson Fall 2017
USFT-THOMPSON-F17S1G6
3 членов
Автор 10 руководств
2 Комментариев
thank for sharing this! I want to check if it is easy to swap HDD/SSD?
pama - Ответить
I'm grateful for the individuals who take time to share their knowledge. I'm 63yrs young with no technical skills. I followed your step by step instructions and was successful in changing my laptop battery. THANK YOU! 👩‍🦳👍
iamelara - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 15
За последние 30 дней: 36
За всё время: 13,870
