Введение
This guide will walk you through the process of removing the cooling fans in your Lenovo IdeaPad Flex 6-14IKB. This guide is helpful if your laptop is overheating. Your fans may need to be replaced, or simply cleaned if they are clogged with dust. Removing the fan is a simple task, but it is important to make sure you have thermal paste on hand for when it is time to reinstall the fan.
Выберете то, что вам нужно
Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
Use the plastic opening tool to pry in the seam between the bottom cover and the rest of the laptop.
Work your way around the bottom cover of the laptop in a clockwise rotation until every clip is free.
Remove the six 3.5 mm screws that secure the fans in place using a Phillips #00 screwdriver.
Loosen the seven captive screws using a Phillips #00 screwdriver.
Lift the black piece of cloth tape that secures the right side fan wires to the circuit board.
