Введение
This guide is about replacing the motherboard of the Lenovo IdeaPad 320-17IKB.
The motherboard is a printed circuit board and foundation of a computer that allocates power and allows communication between the CPU, RAM, and all other computer hardware components. The motherboard is the most important component of the computer. An outdated or damaged motherboard negatively affects the performance of the computer and sometimes has to be replaced.
Before using this guide, check out the Lenovo IdeaPad 320-17IKB Troubleshooting. Sometimes, the damaged back panel is the reason of disrupting the motherboard and other hardware. As a result, the motherboard does not have to be replaced in that case.
Be cautious when lifting the back panel off the laptop to not damage any hardware.
Выберете то, что вам нужно
Use your fingers or an opening tool to gently remove the back panel from the bottom of the laptop.
Lay both sides of the laptop next to each other.
Pinch the connecting cord with one hand and pry the battery connector with the other hand, while gently pulling the connector straight out and towards the bottom edge of the base.
Gently lift the fan assembly out of the laptop.
Gently remove the connecting wires from the exterior of the fan by slowly "weaving" the cord between the ridges of the fan.
Remove the single 3mm Phillips #0 screw from the Wi-Fi card.
Pull the Wi-Fi card straight out of the laptop.
Using a Jimmy, gently pry the motherboard from under the corner screw holder with one hand and pull the motherboard out with the other.
3 участников успешно повторили данное руководство.
