Lenovo Tab S8 Battery Replacement
Выберете то, что вам нужно
  1. Lenovo Tab S8 Battery Replacement, Battery: шаг 1, изображение 1 из 2 Lenovo Tab S8 Battery Replacement, Battery: шаг 1, изображение 2 из 2
    • Make sure the device is powered off.
    • Gently insert a spudger into one of the bottom corners between the screen and body case.
    • Slide the spudger along the inside of the crack in order to pry the case open.
    • Be careful of the small volume and power buttons when prying the case with the spudger. They are connected with small pieces of plastic that break easily.
  2. Lenovo Tab S8 Battery Replacement: шаг 2, изображение 1 из 3 Lenovo Tab S8 Battery Replacement: шаг 2, изображение 2 из 3 Lenovo Tab S8 Battery Replacement: шаг 2, изображение 3 из 3
    • After removing the cover, remove the M1.6 x 2 mm screw from the battery cable with the JIS J000 screwdriver.
    • Using screwdriver bits that do not fit in the screw head might strip the screw and render it unusable.
    • Remove the tape by gently scraping the edges up with the spudger.
  3. Lenovo Tab S8 Battery Replacement: шаг 3, изображение 1 из 3 Lenovo Tab S8 Battery Replacement: шаг 3, изображение 2 из 3 Lenovo Tab S8 Battery Replacement: шаг 3, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Plastic Cards
    $2.99
    Купить
    • Before removing the battery, be sure to disconnect the ribbon cables underneath it. The cables might stick to the battery during removal and cause damage.
    • Gently lift the flaps on the four ZIF connectors to disconnect the cables.
    • Use the plastic card to gently pry the battery from the device.
    • There may be glue holding the battery to the device. Use the spudger to detach any glue while the battery is partially raised by the card.
Заключение
15 участников успешно повторили данное руководство.
Temi Adegoke
Участник с: 08/26/15
417 Репутация
1 руководство автора
Команда
USF Tampa, Team 3-6, Eyestone Fall 2015 Участник USF Tampa, Team 3-6, Eyestone Fall 2015
USFT-EYESTONE-F15S3G6
3 членов
Автор 11 руководств
Один комментарий
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 33
За последние 30 дней: 115
За всё время: 13,548
