Введение
Welcome to the external battery replacement guide for the Lenovo Thinkpad T580.
This guide will detail the steps necessary to replace the external battery.
The most common reasons why this component would need to be replaced is because:
- The external battery has gone bad.
- The port is damaged.
- The battery no longer recharges as effectively.
If you are not experiencing these problems with this component, consider examining the troubleshooting page for this device.
There are no specialized skills required for replacing the external battery.
You do not need to buy a second replacement battery if your goal is just to remove the external battery.
Выберете то, что вам нужно
Slide the switch on the right side of the battery to the right while applying upward pressure on the battery.
Еще один человек закончил это руководство.
