Lenovo ThinkPad X1 Yoga (6th Gen) Coin Cell Battery Replacement
Выберете то, что вам нужно
  1. Lenovo ThinkPad X1 Yoga (6th Gen) Coin Cell Battery Replacement, Base Panel: шаг 1, изображение 1 из 3 Lenovo ThinkPad X1 Yoga (6th Gen) Coin Cell Battery Replacement, Base Panel: шаг 1, изображение 2 из 3 Lenovo ThinkPad X1 Yoga (6th Gen) Coin Cell Battery Replacement, Base Panel: шаг 1, изображение 3 из 3
    • Use a Phillips #1 screwdriver to remove the five 5.0 mm screws from the base panel.
    • Wedge a spudger between the base panel and chassis, and pry around the entire perimeter until you hear a pop and the base panel releases.
    • Lift the base panel up and off of the chassis.
  2. Lenovo ThinkPad X1 Yoga (6th Gen) Coin Cell Battery Replacement, Battery: шаг 2, изображение 1 из 3 Lenovo ThinkPad X1 Yoga (6th Gen) Coin Cell Battery Replacement, Battery: шаг 2, изображение 2 из 3 Lenovo ThinkPad X1 Yoga (6th Gen) Coin Cell Battery Replacement, Battery: шаг 2, изображение 3 из 3
    • Use a Phillips #1 screwdriver to remove the five 4.5 mm screws securing the battery.
    • Lift the battery up and out.
  3. Lenovo ThinkPad X1 Yoga (6th Gen) Coin Cell Battery Replacement, Coin Cell Battery: шаг 3, изображение 1 из 2 Lenovo ThinkPad X1 Yoga (6th Gen) Coin Cell Battery Replacement, Coin Cell Battery: шаг 3, изображение 2 из 2
    • Use a spudger to pry the coin cell battery until it releases from the chassis.
    • There is an adhesive holding the battery in place; patiently pry around the coin cell until it releases from the housing, and don't use excessive force.
  4. Lenovo ThinkPad X1 Yoga (6th Gen) Coin Cell Battery Replacement: шаг 4, изображение 1 из 3 Lenovo ThinkPad X1 Yoga (6th Gen) Coin Cell Battery Replacement: шаг 4, изображение 2 из 3 Lenovo ThinkPad X1 Yoga (6th Gen) Coin Cell Battery Replacement: шаг 4, изображение 3 из 3
    • Use a spudger to "walk" out the coin cell's plug from its motherboard port, gently levering from each side until it releases.
    • Lift the coin cell battery out.
Заключение
Taylor Morgan
Участник с: 02/15/22
521 Репутация
Автор 5 руководств
Команда
Western Carolina University, Team 1-1, Virtue Spring 2022 Участник Western Carolina University, Team 1-1, Virtue Spring 2022
WCU-VIRTUE-S22S1G1
4 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 8
За последние 30 дней: 20
За всё время: 359
