Lenovo Yoga 3 Pro Battery Replacement
Выберете то, что вам нужно
  1. Lenovo Yoga 3 Pro Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Before opening your laptop, make sure it is powered off.
    • Remove the ten 3.3 mm screws from the base cover using a T5 Torx screwdriver.
  2. Lenovo Yoga 3 Pro Battery Replacement: шаг 2, изображение 1 из 1
    • Slide the plastic opening tool between the base cover and the frame to pry open the computer.
    • Slowly go around the entire perimeter of the computer until all edges are loose.
    • Make sure the plastic opening tool doesn't go too far into the device.
  3. Lenovo Yoga 3 Pro Battery Replacement: шаг 3, изображение 1 из 1
    • Remove the panel and place it in a safe location.
  4. Lenovo Yoga 3 Pro Battery Replacement: шаг 4, изображение 1 из 1
    • Remove the six 3.5 mm screws surrounding the battery using a Phillips 00 screwdriver.
  5. Lenovo Yoga 3 Pro Battery Replacement: шаг 5, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
  6. Lenovo Yoga 3 Pro Battery Replacement: шаг 6, изображение 1 из 1
    • Carefully lift and remove the battery.
Заключение
26 человек успешно провели ремонт по этому руководству.
Federico LopezCasildo Jr
Участник с: 10/08/15
1 340 Репутация
Автор 3 руководств
Команду
Cal Poly, Team 12-17, Maness Fall 2015 Участник Cal Poly, Team 12-17, Maness Fall 2015
CPSU-MANESS-F15S12G17
4 членов
Автор 15 руководств
8Комментарии к руководству
Very good and very easy to understand
barri.smith - Ответить
Your really good love watching how you take apart Samsung S5 me I want to take out my mother board
and replace it with a motherboard that recognizes Optus and also download the firmware which it cannot do right now
had it repaired stuffed the phone right up so not sure if I can do this as good as you have the tools
Raewyn Dowd - Ответить
does this same process work for a lonovo yoga pro 2?
Abi Alexander - Ответить
Awesome and simple! Thank you!
Hong K. Nguyen - Ответить
I have changed my battery and it won't turn on. I followed all the steps and the changing light won't even light up. My laptop with the old battery was working (only when connected). Not sure what to do next?
Erika
Erika Mackintosh - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 22
За последние 30 дней: 137
За всё время: 61,510
