Введение
If your device isn’t charging or loses charge quickly, it may be time to replace the battery. Follow the instructions below to replace the battery in the Lenovo Yoga C940-IIL laptop.
Запчасти
Детали не указаны.
Using the Phillips #0 screwdriver, remove the three screws underneath the rubber foot.
Using the T5 Torx screwdriver, remove the four remaining screws on the outside of the frame.
The battery is held in place by four screws, one of which is hidden.
Remove this small piece of rubber is covering one of the screws with your fingers.
Use the Phillips #0 screwdriver to remove the four screws securing the battery to the device.
To complete the removal of the battery, disconnect the ribbon cable connecting the battery to the computer.
For optimal performance, after completing this guide, calibrate your newly installed battery.
