Введение
This guide requires both soldering skills and the removal of the battery.
Выберете то, что вам нужно
With the device screen face down, use the metal spudger to remove the small rubber circles on all four corners of the device. The screws should now be revealed.
Using the metal spudger, pry open the small, long rubber rectangle on the back of the device to reveal more screws.
Using a Phillips #00 screwdriver, remove the four 6.8mm screws from the four corners of the device.
Using the same screwdriver, remove the three screws that were behind the rubber rectangle. These screws do not come out of the device.
Use the plastic opening tool to gently pry open the back panel of the tablet.
Using the plastic opening tool, gently pry the speaker out of its plastic housing.
Solder the speaker off the motherboard.
For how to solder, check out iFixit's Soldering Guide.
