Lighting: Replacing Light Emitting Diode
Выберете то, что вам нужно
  1. Lighting: Replacing Light Emitting Diode, Light Emitting Diode: шаг 1, изображение 1 из 1
    • Using a plastic opening tool, remove the base of the Light Angel.
    • Insert the plastic opening tool between the base and the LED housing and pull outwards on the handle.
  2. Lighting: Replacing Light Emitting Diode: шаг 2, изображение 1 из 1
    • Using a Phillips head jeweler's screwdriver, remove the screw on the battery housing.
    • To remove the screw, turn counterclockwise.
    • Remember to put all the screws you take out somewhere safe so you can find them when it's time to reassemble the light.
  3. Lighting: Replacing Light Emitting Diode: шаг 3, изображение 1 из 1
    • Remove and set aside the (4) AA batteries in the battery housing.
  4. Lighting: Replacing Light Emitting Diode: шаг 4, изображение 1 из 1
    • Using a Phillips head jeweler's screwdriver, remove the (6) screws holding the LED housing together.
    • To remove the screws, turn counterclockwise.
  5. Lighting: Replacing Light Emitting Diode: шаг 5, изображение 1 из 1
    • Insert the plastic opening tool into the crease on the side of the LED housing to separate it from the rest of the device.
  6. Lighting: Replacing Light Emitting Diode: шаг 6, изображение 1 из 1
    • Locate the faulty light emitting diode on the back of the circuit board.
    • Using a soldering iron and desoldering braid, unsolder the connection on the light emitting diode.
    • Do not allow the soldering iron to come in contact with other components on the circuit board.
    • For detailed instructions on how to solder go to How To Solder and Desolder Connections
  7. Lighting: Replacing Light Emitting Diode: шаг 7, изображение 1 из 1
    • Insert the new light emitting diode through the two holes left from removing the old one.
    • Note: the picture is not of the Light Angel circuit board. It is a general example of inserting a light emitting diode on a circuit board. Photo Credit: How To Solder and Desolder Connections
  8. Lighting: Replacing Light Emitting Diode: шаг 8, изображение 1 из 1
    • Using solder and a soldering iron, solder the new LED to the circuit board.
    • Keep your solder joints separate to avoid short circuiting the circuit board.
Заключение
2 участников успешно повторили данное руководство.
Matthew Corigliano
Участник с: 02/10/16
155 Репутация
1 руководство автора
Команда
Colorado Springs, Team 8-6, Mcmichael Spring 2016 Участник Colorado Springs, Team 8-6, Mcmichael Spring 2016
UCCS-MCMICHAEL-S16S8G6
3 членов
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 18
За последние 30 дней: 78
За всё время: 4,673
