Введение
Replacing the battery is often a simple and effective solution for resolving the issue of the device not powering on. If your Little Tikes Tobi 2 Interactive Karaoke Machine fails to respond or shows no signs of life, the batteries may be drained or improperly installed. To address this, you will need four new AA alkaline batteries—preferably from a reliable brand to ensure optimal performance and longevity.
Выберете то, что вам нужно
Use a Phillips screwdriver to remove the single screw that is holding the cover to the battery compartment.
Use a spudger to carefully pry off the battery cover.
To easily pop out a battery, use your thumb to push the battery from the flat side down toward the coil and pull the battery outward.
Remove all four batteries.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
