Logitech G27 Optical Encoder Replacement
Выберете то, что вам нужно
  1. Logitech G27 Optical Encoder Replacement, Steering Wheel: шаг 1, изображение 1 из 1
    • Remove the six gray 25mm hex screws with a 4mm allen wrench.
    • Watch out when you lift the wheel up, as there are fragile wires connected to the bottom side.
    • Carefully lift up the wheel, but do not disconnect it from the rest of the device.
    Спросите у FixBot
    Добавить комментарий
  2. Logitech G27 Optical Encoder Replacement: шаг 2, изображение 1 из 1
    • Carefully lift the wheel off of the hub, exposing the 2 shifter paddle wires and PCB board.
    Спросите у FixBot
  3. Logitech G27 Optical Encoder Replacement: шаг 3, изображение 1 из 1
    • Remove the two 7.5 mm silver screws holding the green PCB board in the wheel with a Phillips #1 screwdriver.
    Спросите у FixBot
  4. Logitech G27 Optical Encoder Replacement: шаг 4, изображение 1 из 1
    • Carefully remove the PCB board from the wheel hub.
    Спросите у FixBot
  5. Logitech G27 Optical Encoder Replacement: шаг 5, изображение 1 из 1
    • Carefully pinch and unplug the large 7-pin connector under the PCB board.
    • Be careful when unplugging this adapter, try not to pull on the wires to avoid damaging them. Instead, wiggle around the plastic connector while pulling on it to loosen it.
    Спросите у FixBot
  6. Logitech G27 Optical Encoder Replacement: шаг 6, изображение 1 из 1
    • You can now fully remove the wheel from the hub. Set it aside until you put the wheel back together.
    • Remove the innermost three 37.5mm silver screws with a Phillips #2 screwdriver.
    • Remove the wheel hub and push the connector through the center of the hub.
    Спросите у FixBot
  7. Logitech G27 Optical Encoder Replacement: шаг 7, изображение 1 из 1
    • The wheel hub can now be set aside and flip over the steering wheel housing to reveal the under side.
    • Remove the eight 15.9mm silver surrounding screws underneath the wheel housing with a Phillips #1 screwdriver.
    Спросите у FixBot
  8. Logitech G27 Optical Encoder Replacement: шаг 8, изображение 1 из 1
    • Rotate the housing back over and remove the top half of the housing revealing the majority of the components of the wheel.
    • The housing cover can be set aside until you put the wheel back together.
    Спросите у FixBot
  9. Logitech G27 Optical Encoder Replacement: шаг 9, изображение 1 из 1
    • Remove the four 7.3mm silver screws attaching the green PCB board to the motor housing with a Phillips #2 screwdriver.
    Спросите у FixBot
  10. Logitech G27 Optical Encoder Replacement: шаг 10, изображение 1 из 1
    • Unplug the three plastic connectors on the left side of the PCB board.
    • Unplug the two plastic connectors on the top of the PCB board.
    • Unplug the three plastic connectors on the right side of the PCB board.
    • Pulling the plastic connectors requires a lot of force, but be careful and don't pull directly on the wires. Try to wedge or push the male side of the connector out.
    • If you need some extra leverage when removing these connectors, try using a plastic opening tool to pry off the connectors.
    • Removing these connectors allows easier access to the four screws attaching the PCB board mount to the motor housing.
    Спросите у FixBot
  11. Logitech G27 Optical Encoder Replacement: шаг 11, изображение 1 из 1
    • Remove the PCB board after all of the plastic connectors are disconnected.
    • You can now set it aside.
    Спросите у FixBot
  12. Logitech G27 Optical Encoder Replacement: шаг 12, изображение 1 из 1
    • Remove the two 12.3mm upper black screws with a Phillips #2 screwdriver.
    • Remove the two 15.5mm bottom silver screws with a Phillips #1 screwdriver.
    Спросите у FixBot
  13. Logitech G27 Optical Encoder Replacement: шаг 13, изображение 1 из 2 Logitech G27 Optical Encoder Replacement: шаг 13, изображение 2 из 2
    • Remove the PCB board mount and remove the clear plastic piece underneath.
    • Set them aside until you reassemble the wheel.
    Спросите у FixBot
  14. Logitech G27 Optical Encoder Replacement, Optical Encoder: шаг 14, изображение 1 из 2 Logitech G27 Optical Encoder Replacement, Optical Encoder: шаг 14, изображение 2 из 2
    • After following the prerequisite guide, invert your device.
    • Remove the four center-most screws from the bottom of the device with a Phillips #1 screwdriver.
    • Invert your device back to its original position, and completely remove the motor housing from the rest of the device.
    Спросите у FixBot
  15. Logitech G27 Optical Encoder Replacement: шаг 15, изображение 1 из 1
    • Remove the eight screws attaching the metal motor housing to the plastic with a Phillips #1 screwdriver.
    • Completely remove the motor housing from the plastic.
    • In this picture, the optical encoder is attached to the end of the right-most motor. It has a black plastic case around it for protection.
    Спросите у FixBot
  16. Logitech G27 Optical Encoder Replacement: шаг 16, изображение 1 из 1
    • Turn the device around, and remove the three screws attaching the left most motor to the metal backing using a Phillips #1 screwdriver.
    • Completely remove the motor from the metal backing. This will make it easier to move around when replacing the optical encoder.
    Спросите у FixBot
  17. Logitech G27 Optical Encoder Replacement: шаг 17, изображение 1 из 2 Logitech G27 Optical Encoder Replacement: шаг 17, изображение 2 из 2
    • Remove the white 5-pin adapter from the end of the optical encoder.
    • Use the same amount of caution with this adapter as you did with all the others: don't pull directly on the wires and wiggle it out.
    • Remove the plastic casing by prying it off with a screwdriver or a plastic opening tool.
    Спросите у FixBot
  18. Logitech G27 Optical Encoder Replacement: шаг 18, изображение 1 из 1
    • Remove the two silver screws from the underside of the optical encoder with a Phillips #0 screwdriver, and the circuit will be free from the motor and ready to replace!
    • Be careful not to bend the light or the black receiver that stick up off the board. If they don't line up, your wheel won't be able to calibrate at all and you'll have a very hard time trying to line them back up.
    Спросите у FixBot
  19. Logitech G27 Optical Encoder Replacement: шаг 19, изображение 1 из 3 Logitech G27 Optical Encoder Replacement: шаг 19, изображение 2 из 3 Logitech G27 Optical Encoder Replacement: шаг 19, изображение 3 из 3
    • During reinstallation make sure when doing this step to align the stop on the wheel gear with the track as shown in the second and third pictures.
    • Also make sure that the metal half-circle clip is placed properly inside the slot.
    • After placing the metal clip in the slot, place the plastic cog on top of the clip and on the rail.
    Спросите у FixBot
Заключение
52 человек успешно провели ремонт по этому руководству.
Grant Blake
Участник с: 04/21/15
1 782 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 15-4, Amido Spring 2015 Участник Cal Poly, Team 15-4, Amido Spring 2015
CPSU-AMIDO-S15S15G4
4 членов
Автор 25 руководств
35 Комментарии к руководству
Where can you get the encoder to replace it?
invertig0 - Ответить Поделиться
If your wheel doesn't calibrate.Then check your optical encoder. It's 90 percent of the issue You can find replacement in the ETSY with the buyer name " abrapartabra " for logitech optical encoder 30 or 60 slot they have for Logitech G25 , G27 and DFGT . They have been made like original, but with more reliable plastic. We fixed our Logitech steering wheel
Fixer - Ответить Поделиться
Hello and thanks for the guide. I understand this might be off topic, but would you happen to know the pinout of the7-pin connector in step 5? There is no label on the pins. Thanks in advance for your time.
Georgios Arkouzis - Ответить Поделиться
Very much appreciate your assistance & time putting this together. I Chose the expoxy route. My wheel IS BACK!
Dave - Ответить Поделиться
Are you sure about Step 19 alignment. Some other guy with G25 says it has to be dead centre alligned otherwise you get blinking lights.And that's exactly what happens to me.
robertleskovsek - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 10
За последние 7 дней: 127
За последние 30 дней: 492
За всё время: 100,090
