Введение
This disassembly will show you how to get into your Logitech K860.
Выберете то, что вам нужно
Anyway, you need to unclip the wrist pad and unscrew some stuff again. Like 4-5 screws here.
As the frame comes apart be mindful that they are connected via this on/off switch. Carefully wiggle one of the connectors to unplug, and set the base aside.
To unattach the plate we need to break each one with a sharp knife, by cracking and lifting away some of the flattened, mushroomed 'head'. While this is irreversible, it will not prevent the operation of the keyboard. Later, the screws which have already been removed will now bear the entire load of holding these components together.
Now you are left with this beautiful view. You can unscrew the ground for the small board and the board itself. You can even unscrew 2 screws on either side of the keyboard.
9 человек успешно провели ремонт по этому руководству.
9 Комментарии к руководству
Great guide! the part about the hidden screw under the serial number in particular was a life saver.
One thing that's not clear is which slots take the smaller vs the larger screws, it would help to annotate that as now I'm blindly screwing whatever fits.
OK so IINM, the 6 small screws all go on the upper half of the reverse side. There is also one slot for a longer screw (closest to the power switch). Anyway the longer screws don't fit in the small slots so it's easy.
Great guide. But I have 2 buttons that are not working, if it can not get to te membrane how can i test it or clean it?
that's ridiculous that you can't do that. I have the same issue.
