Logitech UE Megaboom 4 Speaker Replacement
Выберете то, что вам нужно
  1. Logitech UE Megaboom 4 Speaker Replacement, Outer Case: шаг 1, изображение 1 из 3 Logitech UE Megaboom 4 Speaker Replacement, Outer Case: шаг 1, изображение 2 из 3 Logitech UE Megaboom 4 Speaker Replacement, Outer Case: шаг 1, изображение 3 из 3
    • Flip your speaker upside down so the charging port side is faced upwards.
    • Place the end of a metal spudger in between the rubber bottom and the mesh case.
    • Work your way around the base of the speaker until the top separates from the case of the speaker.
    • This will take force.
    • Use the metal spudger carefully. Improper use may lead to injury.
  2. Logitech UE Megaboom 4 Speaker Replacement: шаг 2, изображение 1 из 1
    • Pull the bottom end of the speaker off and place it aside.
    • Once the glued seal is broken you will be able to pull it off with your hands.
  3. Logitech UE Megaboom 4 Speaker Replacement: шаг 3, изображение 1 из 3 Logitech UE Megaboom 4 Speaker Replacement: шаг 3, изображение 2 из 3 Logitech UE Megaboom 4 Speaker Replacement: шаг 3, изображение 3 из 3
    • Use your thumbs to press the two plastic tabs inside the speaker case and gently push out the internal components.
    • The inside components will begin to slide out of the top from the mesh casing.
  4. Logitech UE Megaboom 4 Speaker Replacement: шаг 4, изображение 1 из 1
    • The internal components of the Logitech UE MegaBoom 4 speaker are now separated from the outer case.
  5. Logitech UE Megaboom 4 Speaker Replacement, Speaker: шаг 5, изображение 1 из 2 Logitech UE Megaboom 4 Speaker Replacement, Speaker: шаг 5, изображение 2 из 2
    • Use a metal spudger or another suitable opening tool to push the metal rods on both sides of the speaker until they extend past the end of the device.
    • When the rods are pushed out far enough, use pliers to pull them out the rest of the way.
    • Repeat for each metal rod on the speaker.
  6. Logitech UE Megaboom 4 Speaker Replacement: шаг 6, изображение 1 из 2 Logitech UE Megaboom 4 Speaker Replacement: шаг 6, изображение 2 из 2
    • Use a spudger to apply an upward force on the speaker plate.
    • Hold the speaker with one hand and use a spudger to pry the speaker off.
    • This will take some force.
  7. Logitech UE Megaboom 4 Speaker Replacement: шаг 7, изображение 1 из 2 Logitech UE Megaboom 4 Speaker Replacement: шаг 7, изображение 2 из 2
    • Squeeze the end of the connector to release it from the socket and remove the speaker cables from the motherboard.
    • If you have difficulty removing the speaker connector, take a look at the Recognizing and Disconnecting Cable Connectors guide for additional help.
Заключение
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Eden Norris
Участник с: 02/10/25
216 Репутация
Автор 2 руководств
Команда
University of North Texas, Team 1-4, Kilpatrick Spring 2025 Участник University of North Texas, Team 1-4, Kilpatrick Spring 2025
UNT-KILPATRICK-S25S1G4
4 членов
Автор 6 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 9
За последние 30 дней: 56
За всё время: 253
