Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Slide the lock switch to the right, to the unlocked position.
Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
While supporting the fan assembly with one hand, loosen the two T8 captive screws in the fan cable bracket.
Инструмент, используемый на этом этапе:Tweezers$4.99-
Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
Disconnect the fan assembly antenna cable from the IO board.
Remove the fan assembly from the Mac Pro.
Remove five 5.1 mm T10 Torx screws from the outer perimeter of the lower case.
Carefully lift the lower case up and remove it from the Mac Pro.
Use the flat end of a spudger and a twisting motion to gently separate one side of the graphics card data connection.
Gently separate the other side as well.
Flip the connector up and out of the way of the graphics card.
Remove the two 6.0 mm T8 Torx screws securing the interconnect board to the heat sink.
Gently walk the interconnect board straight up off the logic board's slot connection.
Flip the interconnect board up and over, exposing the IO board data cable.
Use the same sort of twisting and spreading motion with the flat end of a spudger to separate one side of the IO board data cable.
Use the flat end of a spudger to separate the other side of the IO board data cable.
Bend the cable out of the way and remove the interconnect board from the Mac Pro.
Flip the Mac Pro back over and set it gently on a flat surface.
Remove the two 3.6 mm T5 Torx screws from the sides of the power supply cage (one on each side).
Remove the power supply cage from the top of the power supply.
Remove the four 5.5 mm T8 Torx screws securing the power supply assembly to the Mac Pro.
Remove four 12.8 mm T10 Torx screws from the CPU heat sink bracket.
Remove the inner four 12.8 mm T10 Torx screws from the CPU heat sink bracket.
Remove the CPU heat sink bracket.
Lift and remove the logic board from the CPU and bracket.
During reassembly, be sure to clean off and replace the thermal compound on the CPU.
We have a thermal paste guide that makes replacing the thermal compound easy.
82 участников успешно повторили данное руководство.
46 Комментариев
So this means I can buy the smallest Mac Pro now and upgrade the CPU in a few years, right? I like you guys! :)
Yes, Ben, you could. 2nd hand CpU's are available on eBay, Amazon and various companies. Review suitability of your proposed CPU that it will fit the socket FCLGA2011, and pay attention to voltage. ECC support, and TDP. Switching CPU isn't an easy task and it has risks replacing it.
aramis -
Hi Ben, I found an interesting website with more info regarding CPU upgrade:
https://blog.macsales.com/22230-owcs-mac...
from
aramis -
I just replaced the cheapest 4-core version with the 12 core 2697v2.
This saved me around $700 + i can sell the 4 core.
Can you please provide some benchmarks, i wish to do the same, but need to see if doing this myself creates any problems
